Broke Bolt
toonin22
Anyone know the correct way to remove a corroded broken bolt. Tried heating it and easy out to no prevail, take any and all tips.
partskenn
Re: Broke Bolt
What do you have to work with? Is it busted off flush, or is a piece of the bolt sticking out still? Can you get to the back side of whatever you are working on. And did the easy out just not pull it out, or did you break it off in the bolt.
toonin22
Re: Broke Bolt
I have nothing to work with. And the easy out wouldn't turn it. And yes I can get to the back of it.
Ned L
Re: Broke Bolt
What kind of bolt, how big & what is it in? - Presuming steel bolt in steel or cast iron (engine). Considering you can get to the backside of the bolt (all the way through), if it were me, I would drill it to the tap size & chase the threads with a tap.
How close to 'on center' is your hole for the easy-out? If you are nicely on center then your best bet may be to drill it & chase the threads. Sometimes if you drill to the tap size you can carefully use a center punch to start to role the old remaining bolt threads into the center hole, which makes it much easier to find the original threads with the tap and chase the threads.
rlb9844
Re: Broke Bolt
If its a steel bolt in alluminum be careful drilling. I ruined a set of heads on my old outboard by the drill bit wandering off the bolt.
dingbat
Re: Broke Bolt
What is up with the back side access? I've drilled out more blind threaded holes than I care to remember back in my machinist days
Drill the center of the bolt out as large as you can. No need to get into the threads. Fill the hole with PB blaster and let sit for a couple of minutes. Take a sharp center punch and start at the top. Collapse the bolt inwards. Keep working the bolt with the center punch. It will come out. Needle nose pliers once you get it loose
hungupthespikes
Master Chief Petty Officer
TestEngr
Re: Broke Bolt
As others suggest, if you can get to the back side drill it out slightly smaller than the threads. *Most* of the time it will break loose just from the drilling. If not a small hamer and chisel will get whats left out.
Of course multiple shots of penetrating oil over the course of a couple days can work wonders.
Nothing can beat Kano Kroil penetrating oil.
tswiczko
Re: Broke Bolt
^^^^^^+1 on the Kroil.I bought a set of LH twist drill bits years ago for just such occasions if they are sharp they will usually grab when you get about half way through the bolt and turn it out. I don't know what type of metal you are in or what the bolt is made of but there are many approaches to removing a broken bolt, depends on the situation.
There are also many options if you damage the hole getting the old bolt out,(do you have to ask how I know:redface:) you can also drill to the next size up if you damage the threads, tap and insert a keensert heli-coil http://www.thorintl.com/Keenserts-Keyserts-Keylocking-Inserts.htm if you are in thin metal you can drill it out and use a thin wall fastener http://www.pemnet.com/fastening_products/atlas/index_new.html , or just drill it out and put a nut on the backside if it doesn't interfere with anything.
good luck
cr2k
Re: Broke Bolt
can you heat the alum. around the bolt? That should release it to the easy out.
dockwrecker
Re: Broke Bolt
+2 on left handed drill bits. Hard to find but well worth the investment. I usually center punch and drill the offending bolt with a drill dia. much smaller than the bolt. Let it sit with a proper penetrating solution and then go after it with the left handed bit slightly smaller than the internal thread dia. The trick is to drill completely through the bolt with the small bit first.
toonin22
Re: Broke Bolt
I started small drilled as close to center as possible working my way up. Kept spraying it. Then went to the back with one almost the exact size of the bolt and it came out. I should of checked where to disconnect the shift shaft on an old Johnson. Found it on here tho a little late. Thanks.
