Broken blade in one of my wiring harness connectors
Jbrookins
The 3rd blade on this connector is broken and I'm not sure what to do and if I can order o e from somewhere I don't want to have to replace the entire harness. It connects to the trim pump
Ayuh,.... Yer link is no good,.... Whatcha workin' on,..?? Year,..??
Bt Doctur
the red wire supplies power to the control box handel , that comes off the main buss across the solenoids,the blue is "up" and can be connected directly to the solenoid or thru a connector, same for the green "down."
stonyloam
Being a farmer, and running into similar situations more times than I care to remember, I would suggest the following: Clip the broken wire from either side of the connector, strip the ends and solder them together ( make a short jumper with similar size wire if necessary). A few coats of Liquid Tape will waterproof it. Should be good for a semi-perminate repair.
