Has anyone had any luck removing broken bolts? I recently purchased a motor with 3 bolts broken off. 1 is 1 of the 4 bolts attaching the gear casing to the exaust housing. The other 2 are in the powerhead. <br /><br />I tried an easy out on the bolt for the gear case but had no luck. Should I bring the engine to a machine shop or should I run the motor as it is? It seems as though everything is working as it should.<br /><br />Thanks in advance,<br /><br />Greg Hodges
