broken bolts
ceasefire49Z
trying to find the bolt size for the two bolts depicted here and shown as item 10. have searched all catalogs i could and to no avail. it appears to pass through and attaches to gimbal housing. i have the transom plate at machinisy
ts to have them removed along with two star bolts on y pipe exhaust that broke.
diagram showing bolt:
http://www.marineengine.com/parts/o...=Transom+Plate,+Flywheel+Housing+&+Mounts
diagram showing reverse side and protrusion at top where bolt attaches;
http://www.marineengine.com/parts/o...acturer=OMC+stern+drive&section=Transom+Mount
alldodge
That's a competitor website and is not allowed
Its best in this case to list what drive (VP, OMC, etc) and then list the part number being listed. This way we will have a better chance of looking up what your needing
alldodge
Sorry I'm coming up empty. Was also thinking someone else would see that had more knowledge of the OMC. It would be SAE standard size bolts, so measure the diameter. It should then be
5/16-18 thread
3/8-16
7/16-14
The transom should be 2 to 21/4 thick, then add for washers, nuts and/or depth of housing
Ayuh,..... The Machinist oughta be able to figure it out, they're standard inch measure bolts,......
I'd think 7/16" - 14,...... Maybe 1/2" - 13,.....
Length is whatever ya need,.....
Gr.5s,... no need for gr.8s,..... SS is to soft, 'n corrodes anyways,....
