I just bought at 1996 Splendor 240 with a 7.4 LX and B3. Boat is in fantastic shape and only has 280 hours on it. I was scrambling around the engine compartment and noticed that one stud on each forward motor mount was sheared off. The mounts were not lag bolted in but rather had SS studs coming up from the hull. The Splendor is a cat hull, so stringers in that area are not real large. One stud is holding the mount just fine on each side, and apparently has been for some time. Quite sure the previous owner had no idea.
Pulling the motor in this boat is not an option at this time. Putting a lag bolt in may not be an option due to the pad that the mount is secured to being very thin (hence the reason the studs are there?) How long of a lag bolt would suffice anyway?
What options do I have here? If I try and lag bolt anything in, I risk compromising the hull. Can I survive with one bolt per side? If I had never noticed, would I ever have? baby it and move on with my day?
Thanks!
Thanks!
