Broken fuel tank fill outlet
wetfootwilly
Hi guys...in the process of renovating my boat....the fill and overfill nozzles on my plastic fuel tank broke off....having trouble finding a proper fuel tank replacement....I've looked at ​quite a few sites but no matches.... my next step is a custom poly fuel tank but I think the cost if going to scare me...
I've been tossing the idea to do a back yard fix...mounting a base with a nozzle to attach the gas fill hose... using screws with proper gas resistant gasket.
Am I looking for trouble or is this doable? thanks for any advice
Ayuh,.... Welcome Aboard,.... Yer Plan, sounds like Bomb Making, 101,.....
Google Ocean Link,... They make Bazillions of plastic tanks,.....
wetfootwilly
Thanks Bondo...ya I don't want to blow up lol...thought there might be a safe way to improvise...still no luck on tank...ocean link does not have
right size poly tank...everything I've seen is either too low capacity or too high or too wide. I will look into a custom made..thxs for advice
