FreeBeeTony
- May 15, 2002
- 3,991
While fishing tonight I had a slight problem........
I pulled anchor and started to accelerate and I felt a loss of power.....thought it might be weeds so I put it in reverse and tried again....same thing. I looked at my son and said "somethings wrong". Shut the engine down and opened the cover to find water everywhere......I immediately thought of the bellows because I just replaced them this year. I started the engine to find the "return" hose on the raw water side of the heat exchanger was loose spraying water.......the hose clamp was broken!!
I took a hose clamp off the scupper hose (had them doubled below the water line!) and installed it on the heat exchanger.......started the engine w/ no problems, guess things were getting wet when I was loosing power!! Engine seemed fine after the leak was fixed!
Only concern I have is the water (salt water) was running over the alternator........seemed fine.....voltage was normal on the gauge.
Ran out of daylight.........going to give it a WD40 bath as soon as I can.
