My X-press bass boat is powered by a 1998 Yamaha 90 HP. A couple of weeks ago I was out fishing and noticed my water pressure gage was reading 1 lb. I looked back at the tell tale and it was producing a moderate stream. (it seemed pretty normal). I ran the boat as usual and dismissed a serious problem. The next day I decided to inspect the water pump. Upon disassembly I found that 3 of the 6 impeller blades had broken off at the tips. I purchased a complete pump rebuild kit, put it all back together, put the earmuffs on it and ran the motor for a few minutes. The gage pressure was back to normal and all was well. My question is, where did those pieces go? I did also pull the T-stat, valve and spring and saw nothing there. Obviously the pieces were broken the day that I went fishing and the motor ran flawlessly. Should I have to worry about a cooling problem next time I use the boat? I have no water temp or head temp gage, only the overheat sensor. Should I install a gage?
