broken prop. need help with specs.
trevskidoo
72 merc 1150. I hit a rock and broke the prop. Need a new one. So confused with pitch and such. Any help? Also what's hubs an such?
mr 88
There should be numbers on the outside of the hub next to where the prop shaft pokes through. Hopefully you did not bend that , although I suspect you have a aluminum prop which takes the brunt of the force vs a SS prop.
trevskidoo
SO im still trying too pull this off haha. Anyways, should i stick to whatever size prop this is.. or? Its a 72 cobia, center console fisherman. 19.5, 115hp,
