This weekend i had a little accident which is upsetting, but im going to buy parts and fix asap! my DP-A suspension fork cracked in half at the top by the water inlet and at the bottom as well, what happened is after sitting in a cove for awhile i reved the motor a few times and the third time was to about 1800 rpm, then WHammm! it popped into gear somehow, i got back into nuetral and went into gear and reverse fine, but i started moving then i had very little steering, so i put it on the trailer. a noticed the fork cracked pretty much in half!!! would that be a saefty thing , that breaking first so something else does or just bad luck because a new one is 825 bux
got to pay to play..I also want to know what else i should check for in that area..bearings? seals? ect? while im in there doing the repair?
thanks mates
thanks mates
