BRP control box
flyingscott
sell the controls with the motor and make sure the motor you buy has controls.
Rranger
It should be so easy. But it's not. New owner doesn't need the controls.
Ayuh,... Generally speakin', controllers won't swap 'tween manufacturers,....
gm280
Generally remote control units are designed to be a plug and play type setup. However, the typical throws for the shifting and throttle controls are setup for the type engine that are made for. So if you were to try and change one for the other, not only would there be a wiring problem, but also the proper throw capabilities as well. Can it be done? YES, but not without much altering and refitting a lot of things. So follow Bondo's suggestion and buy the proper controls for the engine and enjoy boating. JMHO!
