txarmydude
- Oct 24, 2010
- 119
My bilge pump is now functioning as it should in the electrical department. I replaced a bad breaker and it came back to life. There is a little water in my hull; it is not a whole lot. There is not enough water to engage the float switch, which DOES work BTW. But when I turn the bilge pump on, no water is pumped out of the holes in the sides. I can hear a bubbling sound, like when you blow through a straw into a glass of water.
The only thing I can think of is that maybe the bilge pump is clogged up. Any other ideas???
