buick roadmaster for towing
rocky100
hey all!
The 1995 Buick Roadmaster has a towing capacity of 5000 lbs----who knew?
Rocky
MikDee
Banned
Re: buick roadmaster for towing
Who says? it only has a 264cu in V8,,, smaller then a 55' Chevy V8 at 265 cu inches, but mostly having a longer stroke.
SpinnerBait_Nut
Nope, they use the LT1 engine same as the vette backed by 4 speed electronic auto. introduced in '94.
And yep, 5000 lb towing capacity on the Roadmaster and Roadmaster estate wagon.
a70eliminator
Thats quite a load my lincoln only has a 2000lb tow rating, I think my 20' boat alone weight 2,400lb add trailer and it's way over the limit, but I'm going to try anyhow, the lincoln has a 5.0 HO.
kenmyfam
I dont really think that is a wise idea. You still have to add whatever else is in the boat (fuel, gear etc) as well as possibly the tounge weight that has to be subtracted.
Just my personal opinion, others may have towed with this vehicle with great success.
I learned from towing 2,000lb with a Ford Windstar !!!! BOOM !!!!!! goes the tranny !!!!
tashasdaddy
the top of the line Buicks have always been great tow vehicles. the old Electra 225 never thought twice. dad always had a Buick since 53.
MikDee
Banned
Whoops Very Sorry!,,, it must have been a Freudian slip,,, for some reason I thought it said a 1955 Buick :eek: :redface:,,, LOL. That was my first real car, a 1955 Buick 2dr black & white, V8 stick shift, (with a slipping clutch) I called it the "Beast". What do they say, The eyes are the first thing to go,,, :eek: I hope at least this provided a good giggle for someone.
By the way, yes some of those later Buicks did have the LT1 engine, and I have no doubt they can tow quite a bit,,, don't know how much, but I would believe maybe 5K lbs.
  • 55' Buick Special 2Dr hdtp my first real car, was my cousins, 2dr hdtp V8 stick shift, a bomb.jpg
Silvertip
Suburbans and Estate Wagons of that era were commonly used to pull very large travel trailers. With a proper rear end gear it will tow just fine and it will make a better tow vehicle than many of todays so called "tow vehicles" rated to tow 5000#.
v1_0
I use a 93 Chevy Caprice Station wagon (w/the large engine) for towing.
The biggest issue is with my wife - she has the feeling that everyone at the ramp is making fun of us. I think that is because I back it up till the rear wheels are at the water and the tailpipe gets submerged (blub blub blub...)
I've had only one incident of getting stuck - we were launching in a makeshift boatramp (sand) and got a bit hung up pulling the trailer out of the water (after launching the boat). I rocked it and got out. Pulling the boat out later that day went very well, though.
-V
tashasdaddy
Mikdee, dads 1st buick was a 53 2 door special. mother got hit by another car in 58, new 58 century, totaled the 53, dad put the 53 engine and drive train into a boat. don't remember much about how he did it, but it had a clutch, and the gears shifted.
jimmbo
The 1994 - 96 Roadmaster has a a 5000 lb rating only if it has the factory towing option, otherwise the limit is 2000lbs. The Towing option includes 2.93 limited slip diff, bigger radiator with engine oil cooler and mechanical clutch fan, auto air shocks, also modified shift points for transmission along with 2 tranny coolers.
Been towing with one for 10 yrs, 370,000 kms
Edit. The LT1 is not exactly the same as the one in the vette. In the Impala, Roadmaster, and Cadillac Brougham, iron heads are used instead of aluminum and a slightly milder cam for better low end torque. The iron heads actually flow better than the aluminum ones.
more info. the Cadillac version of the car, the Brougham, has a 7000lb tow rating
MikDee
Banned
Wow! A clutch, & gears, in a boat? That's something I always wondered about how it would work? imagine that. I started out an Oldsmobile guy, till I got burned by a guy who sold me a beautiful red 57' Olds Starfire convertible with a J2 engine, that had a bad rod bearing (fudged up) ages ago, back it went! from that point I made it my business to learn, & know, about engines. That's when the "hot rod" bug hit, and it's been Chevy, Pontiac, & Mopar, mostly ever since,,, aside from a few Caddies throw in for good measure :D But, I still long for the seductive styling of that 57' Olds, and am still fascinated by it's electronic eye, (for the headlight dimming) drivers spotlight, Wonderbar radio, the 4spd Hydramatic, all the rest of the goodies, as well as all the Chrome! :cool:
reelfishin
I saw an old crabbing boat a few years back around here that had an older Ford motor and a three speed manual trans, it was a mid engine mounted inboard. It moved along pretty good. It was one of those rigs though that just looked like an accident waiting to happen. The engine was mounted out in the open as was the trans and linkage. the clutch was actuated with a long lever on one side of the motor box. He had it running through a conventional boat trans as well, it gave it three speeds in both directions. It looked as if it have been on the water for quite a while too. The worst part was that the exhaust was just a pair of flipped car manifolds, no water cooling at all other than a pump which drew water through the hull to feed the automotive water pump. It dumped the used coolant out the side of the boat through a piece of water pipe. What caught my eye first was how high in the boat the motor sat.
As far as a tow vehicle, the Buick's weak link will be the transmission, it's most likely equipped with a 4L60 or 4L60E, which is an updated version of the old TH700C. The rear axle should be a 10" GM unit, very similar to what is used in may light trucks, and the motor should have no problems at all with the correct gear ratio. The chassis is pretty much rock solid on those, they were built on the same platform as the Chevy Caprice, which was a very common Taxi and Police platform.
I ran an Olds version for years, towed just about anything that you can imagine with no concern for weight limits, that car is still running with over 200K on it. I sold it at 175K. I literally did nothing to it for the 7 years that I had it and I got it with 12K miles on it.
I also ran a Ford Crown Vic wagon for years, it towed pretty good too, I pulled a utility trailer that weighed about 6500 lbs about 80 miles a few times with it with no trouble. I did have to rebuild the trans in that one at about 100k, but it was fine after that to 285K when I sold it. It towed some sort of trailer at least once a week. I pulled a 20' Bayliner with both several times with no problems.
With the proper hitch and maybe equalizing bars, that Buick should be fine.
If you are traveling any real distance, simply add an oversize trans cooler to help protect the trans from any added heat or wear.
Mkos1980
3 Engines were available. LT1 with Iron Heads, L99 264CID 4.3L V8 "Baby LT1" and the Regular 4.3L V6
