Building a new engine cover
GaBoy
I purchased a boat with a plywood/carpet engine cover. My plans are to build another one with marine plywood and what should I seal with, epoxy or fiberglass, or polyurethane? Does anyone have any suggestions?
Chris1956
Re: Building a new engine cover
I used 1/2 Pressure treated plywood and used strips of fiberglass cloth to connect the pieces together. It created a light, strong "doghouse", and made joining fancy angles easy. Cover all the internal and external plywood surfaces with poly resin for water proofing. Reinforce the top rear of the box with a 2X2 across the top to suppport the edge of the plywood. I used a welcome mat for the top of my doghouse. it was glued on and proved very sun and weather resistant and very durable.
rbryant1492_mfb
I am in the same shape you are in. The boat I just bought does not have an engine cover.
Here is my plan for mines
1) 3/4 treated ply
2) west marine poly
Epoxy is really used where u need real strenght such as floors
Poly will get what you need for 1/4 of the cost.
well thats my plan :p
GaBoy
I found some plastic flooring that has the look of teak planking and I am planning on putting on the top of hatch cover and poly over the whole thing. I am trying to find some fasteners to hold hatch down, any ideas????
erikgreen
I'm planning on using those rubber T-handles that they use to hold down fancy truck hoods or race car hoods.. the kind where you grab the handle and stretch the rubber into a U shaped fitting to latch it down.
They cost about $10 a pair at Northern Tool.
Erik
Chris1956
Unless the 3/4 plywood is really required for strength, due to a large flat piece, I think it too heavy for comfort. Using 1/2 plywood and some strategic 2x2 reinforcement will make for a lighter doghouse, with just as much strength as is required. Also, some strategically placed cloth can strengthen an area..
GaBoy
Thanks for the idea on hood hooks for holding down the hatch. I believe that will work just fine but I need them to be flush with deck. Not sure if I am going to use 1/2 or 3/4, I guess it depends on how much space to make it level with deck. If I add the laminate teak on top 1/2 will work better. I may even put some hinges to allow for raising the hatch when doing maintenance.
