Building Boat Bunks BooBoo
Lazy Daze
While making new bunks for my boat i used liquid nails between the carpet and the wood. When i had the bunk upside down on the saw-horses stapling the back side the saw horses must had rubbed in a couple of spots and sucked liquid nails through the carpet.
I was unable to clean the liquid nails from the carpet and now have a couple of spots where the carpet is semi-hard from the liquid nails.
Will these spots destroy my gel-coat as the boat slides on and off?
Any help is appreciated
Georgesalmon
Re: Building Boat Bunks BooBoo
Might abrade the gelcoat if it gets hard enough. I would put another layer of carpet on them to be safe.
spdracr39
In short .... Yes. Chunk it and start over or use a second wrap in carpet. The second wrap method will severely shorten the life of the carpet though so I would just start over and don't use the liquid nail. Stainless staples and quality bunk carpet are more then enough.
MH Hawker
And don't use the liquid nails its good for building but bad on boats , use the galvanized roofing nails to hold the carpet
Yacht Dr.
I think your fine ..
If you damage your bottom it will not be from caulk pentrating your carpet .. its called liquid nail .. not Real nails ....
YD.
Q_ball
Next time try using contact cement. I did all my bunks and my interior with it and its holding up great. I did use staples on the bottom side of the bunks and in the corners on the folds just be be safe. I was I little unsure if it would hold long term on pressure treated lumber but so far so good.
