Re: bulb and hose size matter??
Hi There...
I'm certainly no expert on fuel line sizes, but my little Honda 15 had some sort of metric size fuel line from the tank to the engine and before and after the in-line fuel filter. Honda used some little cheap spring clamps to hold everything together.
When I moved the tank from the stern to the bow (for weight distribution) I decided to replace all those, so I went to my local boat parts store for hose clamps. They recommended a plastic "tie-tie" like one sees in the hardware store to hold electrical wires together. Except these have a little rounded end on them to make the compression equal all the way around the tube. They said everything Mercury makes uses these instead of the "worm screw hose clamps". I bought several at 17 cents each as opposed to the $1.50 per metal clamp.
IM me if ya want a pic of one of them...
Regards,
Steve
