Re: Bulletin
Are you looking to read the bulletin or are you wanting more information on why the clutch replacement?
Here's the bulletin
Well we have a drive in the shop that was run without it being full, Cooked the upper, when I go to look up parts at # 7, says (gearset sliding sleeve & shoe) I was not sure what was in the kit, working with a local dealer, we think?we got it if, not they will call V.P parts, then #8 has see bulletin needed to know what it was about, we need every thing but the input shaft assy. When I did work for a V.P dealer, in 02-04 I replaced shift cones due to not fully engaging until 2000 rpm. I can't remember if that's why the bulletin came out. If you have the info as to why the replacement I would like to know?.
Thanks for bulletin.
Thanks WOODY.
