I have a 2001 19 Cape Horn C/C. I am 99% sure this is the factory trailer and "almost" sure its original bunks/brackets (Performance Trailer).
Brackets and hardware are shot (corrosion) and bunks old with age, so I plan to replace the setup.
My question... I just now noticed the brackets are different heights, 10 inch (front) and 8 inch (back). I assume it was for easier load/unload? Is this normal to do?
I have always been cautious of the hull only 2 inches from the fenders and 2 inch from the transom trailer cross bar... BUT... I have never had a problem loading/unloading the boat.
Should I fix this height difference now? Or stick with a replacement as it sits? I can take pics if needed.
