Re: Bunks do not support transom since I replaced them last week.
I can't believe you said that, HC. What is to prevent putting a hook in the hull??
the strength of the hull. Fiberglass hulls won't melt. You have to have a boat hanging way off the trailer to get a hook.
I can't speak to storing for several years without use; maybe using a boat occasionally straightens them out?
What about sea drives?
Roller trailers seldom go all the way to sit under the transom; you ahve a big problem if the boat shifts forward and the roller ends up behind the boat (BTDT w/a whaler). Look at the whalers: BW says to support the boat on keel rollers and to use short flat bunks more for balance than support.
Now, to clarify, I don't mean no support whatsoever; I mean the vertical plane of the transom does not have to sit directly on support. Whatever support is under the boat near the transom supports it. How near, is the real question. I said "several inches."
I don't know whether the corners on a bunk will dent an aluminum hull on a bouncy road, which is why I restricted my comment to fiberglass.
Seems, too, if OB's can take it, certainly I/O's would even better since their engine blocks (weight) is further forward.
No hook that I know of on my 1988 key West, 17', 70 hp OB, last roller a good foot from the stern.
