Re: burning a piston?
Certainly sounds like you have a piston that is overheating and perhaps melting. It may be caused by: an overlean carb., lack of lubrication, or a cooling problem near #1. I suggest you do a compression test and report on the numbers and try to look in the cylinders with a boroscope. You might be facing an upper teardown. Sorry . . .
erie_guy
Port Clinton, OH
