Burnt Heads
tbirdkidd
Looks like I fried the number 1 and number 4 cylinder heads on my 1984 235 Johnson outboard the cylinder walls are not to bad (very light scoring) in the block, but the head looks like raw cast iron in 1 on the port and 4 on the starbord side. They are pitted so bad they cannot be repaired, what other heads will fit this 235 block? These 235's are hard to find
farmercr
Re: Burnt Heads
A 1989, 175 is the same as the old 235. OMC stared rating hp at the prop plus they went to the looped block. Hope this helps.
