New boat for me and the battery was not charging... Finally got a chance to inspect the regulator rectifier on my 2001 90 HP Johnson (model J90PLSID) and found that the connector wires from the stator are fried.
Questions - 1. Should I just replace the connector and wires or the entire regulator/rectifier and the connector.
2. To replace the connector, can I cut the old wires and splice in new ones or do I need to replace the whole wiring thing from the stator?
3. The boat runs fine should I disconnect the
regulator rectifier from the stator and operate the boat until I can fix it? (and charge the battery after use)?
Some pics
Some pics
