buying a mid 90's 5hp merc that is still in the box
fishbound
What the chances that this 20 year old engine that is still in the box will start and not need any work done? Are there certain things a person should do prior to fueling and starting? 50:1 mix I assume? Follow the break in instructions is always a good idea.
thanks
carholme
Re: buying a mid 90's 5hp merc that is still in the box
If it were mine and still in the box, I would spray some fuel mix at 50:1 into the sparkplug holes and slowly turn it over using the flywheel to get some lube to the rings and walls, change the impeller and give it a try.
Do you have the s/n?
Gerry
MikDee
Banned
I would spray a 50/50 mix of antifreeze/water into the water intake, when first cranking it up, hoping if the impellers at all stuck, it will help free it up. Then on the muffs with a hose before starting.
if its new and in the box, chances are pretty good that it will fire.
I would count on a new impeller just due to age. and probably need to run it for a while to break it in.
fishbound
Gerry
Serial # 1-005201SK and 0D997262. Model is ME 5 S. Internal gas tank?
fishbound
I am not sure what you mean by your last sentence.
carholme
Your s/n comes up as:
MERCURY - ( 5 H.P. (1996 ))
Serial No: 0D997262 Model No: 1005201SK
Parts List for model 1005201SK:
4/5 H.P. (MARINER, MERCURY) - Mercury, Mercruiser, Force, etc. Parts Lookup
Fuel tank mounted to engine, see under FUEL TANK (SERIAL GROUP #1)
If you are not going to change the impeller before you start it, just rotate the flywheel and you will turn the impeller at the same time.
Gerry
MikDee
Banned
Ear muff type of clamp for the lower unit, that lets you hook up a garden hose to it,,, sold at most any marine supply.
Aw, Heck, just throw yours in a 1/2 filled 55gal drum of water to run it, and keep the impeller wet.
fishbound
thanks all for the helpful suggestions!
