Buying an older boat
jobofly
Hey everyone,
I am looking at buying a 89 bay liner ciera 2455, I will get a marine inspection done on it but I was wondering if you guys can give me some helpful tips or advice.
Thanks a ton.
-joe
coolbri70
Re: Buying an older boat
welcome:welcome: have the inspection, safety course, read up the forums are good source of info, and post pics with questions for better help, we all like pics:D
jobofly
Here is a picture
tazrig
jobofly, go here:
1988 Bayliner Marine Corp CIERA Series 2455 SUNBRIDGE (SB) Price, Used Value & Specs | NADAguides
and plug in what options the boat comes with. Depending on where you are located the price seems a bit on the high side. A good surveyor should catch anything big before you agree to buy but things you can check out yourself are:
1) soft flooring
2) leaking windows (water stains on the inside of the boat)
3) milky looking oil from the dipstick
4) Does the oil smell burnt
5) is the trim pump oil milky or fresh
6) does the drive look beat up or is the skeg damaged
7) excessive rust or corrosion on the drive
8) does the wiring under the dash look reasonably neat or does it look like a rats nest
Basically if you look at least several boats you'll start to see fairly quickly which ones have been taken care of and which ones and which ones haven't. Pick the best one and then bring in the surveyor. You'll want to make sure he does a compression test on the motor and removes and pressure tests the drive unit.
jobofly
Wow thanks for all the info, I would not pay more than $5000 for the boat. It will be our first boat, I thought about going newer but I figured for our first boat I shouldn't go crazy. I do want to sea trial it. What should I look for during a sea trial?
jobofly
Bubba how did you like the boat? Most of the time it will be me, my wife and our 2 kids. Would this boat be large enough to bring a couple of more adults?
jobofly
Is it hard to install trim tabs? I'm pretty sure this boat doesn't have them.
jobofly
Ok this boat has trim tabs. It's in great shape, definitely needs a cleaning and most likely a prop. I am going to sea trial it next weekend.
NYBo
That boat will have an OMC drivetrain. Be sure you can get service readily. If it has a King Cobra outdrive (unlikely), that would be a deal-breaker for me. Some places won't work on them.
jobofly
Thanks nybo, I have the serial number from the boat will that tell me if its a king cobra?
