buying carb rebuild kits
ncornett
my local marine dealer has the carb rebuild kits model 0396701 for about $23 per kit (I need 3 for my j60tletd). i found kits here on iboats model 18-7222 for $12.13 each.
Two Questions:
1. Which kit do you recommend?
2. Should I go ahead and get the kit with the float as a complete overhaul of each carb? I was already leaning in that direction.
thanks in advance.
rickdb1boat
Re: buying carb rebuild kits
Personally, I use the OEM kits. For the little bit more money you spend and considering you only do it once in a great while, it's worth it. With floats, of course...
