1983 johnson o /b 70 hp seahorse. Have replaced plugs , good compression, had timed, spark good on all three cylinders ,new cables, new gas tank, no leaks in gas lines, carbs rebuilt,and all connection cleaned. Will start easy and run at low throttle but if you give more gas will die. When I wait it will smooth out and give gas will take off and run very good sometimes take 2 or 3 tries 2 get it going. Need a little help here. By the way, after i get it going i can go up or down on gas work fine. It just bogs down like its not getting enough gas or something or not building enough RPM's to take full throttle. Thanks in advance .
