c-115 losing fire
prentice3780
Got a yamaha c-115, every one in awhile it stops firing (just on first start up) I can try to start I can wait about 15 30 then it might start. Put in lake Sunday and no firepulled out of water started fine put back in no fire. brought home, went back Monday started ran great all day.
MID FL CAP
Re: c-115 losing fire
so you say you'r losing and eletrical conenction somewhere or that it just dooe'nt what to start? What test have you done?
prentice3780
Mostly just on start up, has died a couple of times losing fire then I get started and runs perfect I have checked all wiring and ground wires
also when it dies it is just like turning off key, I have checked allm wiring in the ignition key control box (does anyone know if one plug is not firing
if it would cause the others not to fire I did have one loose plug wire)
