Hello, a brief point form description of the problem.<br /><br />At idle, bottom left cylinder very weak.<br /><br />1. Good spark, even switched coils....no difference.<br />2. Compression 128lbs. consistent on all 4.<br />3. Removed and checked and cleaned carb, looks great.<br />4. Plug gets soaked. (Tried 3 new plugs in that cylinder)<br /> How I know it is weak is that it is the only cylinder that when idling, can remove spark plug cap and no difference in RPM. This situation started after idling engine in a lake for approx. 1 hour.<br />Engine bogs out, or dies if pushed over 4000-4200RPM. Sometimes it will surge in RPM but goes back to not taking full throttle. Will idle and run midrange all day.<br />Please help, any suggestions???
