C90TLRX YAMAHA LOWER UNIT REMOVAL
jstorz
CAN ANYONE TELL ME THE STEPS TO REMOVE THE LOWER UNIT ON MY 90 HP 1999 YAMAHA. I REMOVED THE BOLTS SECURING THE LOWER UNIT,BUT ITS HASNT MOVED AFTER I TAPPED IT.I NEED TO REPLACE THE WATER PUMP.
imported_Lasse
Re: C90TLRX YAMAHA LOWER UNIT REMOVAL
Take a piece of wood or something softer than aluminum and put that on the cavitation plate and tap gently with hammer. Be careful not to tap too hard, the cavitation plate cracks pretty easily. If it starts to move down tap on the other side so it moves straigh down all the time.
jstorz
IVE HOT PRETTY HARD AND IT HASNT EVEN TRIED TO SEPERATE. IS THERE ANYTHING ELSE I NEED TO UNHOOK THAT COULD BE HOLDING IT.
jerkin
On my f115 there is another bolt you can't see that is under the steering adjuster thing (not sure what it's called, circular piece of zinc with a skeg on it) You pop off a rubber cap above it to access the bolt. Remove it then you will see the other bolt for the lower unit. Make sure you note the position so you can put it back the same way.
