Re: CABLE ADJUSTMENT
tanks lou, going tomorrow to drop off boat.lou i can take the boat to the water and it run good at idle, start to rev it up and it skipps very bad and only get to about 20 mph.now i just put this motor in the week new block, crank,cam,rods,lifters,flat-top pistons.etc..... everything new.set timing at 6deg. btdc set dwell at 39deg.new coil,points condenser,rotor,plugs and wires.checked for vac. leaks found none.new carb also,new fuel, fuel filters,electric fuel pump new (psi 6-7 ). just will not stop skipping ,got to be electical cutting it off .<br /><br /> thanks for any advice
