I have a 79 140 with surface mount contols. Just installed a carb and got it running well. The throttle cable adjuster is all the way forward on the cable and it won't pull the throttle arm back quite far enough to reach timing retard stop bolt which is set to 0 to -2 degress to get the best idle.. I also can not get enuff travel to reach the max throttle stop. which I adjusted by the the book. If I move the adjuster to get full throttle my idle goes up. have tried adjusting the sync screw on the carb but it doesn't help because unless I can pull the timing back I don't get the idle I want which is about 800 in neutral in a barrel. <br />So question is there anyway to get more travel from the control box or does anyone else have any Ideas? Thanks for all your help <br />one more question could this be affected by the throttle cam adjusting screw. I may have moved this at one point during the long process of trying to get this thing to run right but I don't remember for sure?
