Re: calling tabman 2
mattttt25,<br /><br />Well, lets start by finding out what you would like to gain by installing trim tabs, since performance gain can mean many different things to different people. Any vessel can benefit from installing trim tabs, some examples are Increase Performance (reduced pounding, list correction, eliminate porpoising, offset prop torque), Increase Efficiency (reduce fuel consumption & engine laboring, eliminate squatting), & Increase Safety (improve visibility, reduce wake, reduce hull stress). Your 20' Sunbird by our General Sizing Recommendations falls in the 18 x 9 trim tab range, but depending on the Available Mounting Area you may have to step down in size (16 x 12, 14 x 12, or 12 x 12). The next thing to check is Available Mounting Area, that is determined by starting 3-4" from the chine and measuring to within 8" of the outdrive. The measurement that you get will be the Available Mounting Area you have to work with. In general, the largest trim tabs that will comfortably fit on the transom will be the most efficient. Check the transom for protrusions (transducers, speed wheels...). Protrusions may have to be moved before the trim tabs can be installed, or influence your choice of trim tabs. The closer you can stay to the 18 x 9s the better the performance will be for slow speeds and hole shot. Some vessels have plumbing troubles because of their design, but we have a few tricks that will normally cover any situation you run up against. It is just a matter of taken a look and explaining to me your woes. So, please take a look at your transom and get back to me with your findings.<br /><br />I look forward to your reply.<br /><br />Sincerely,<br />MJ Thomas<br />Bennett Marine, Inc.<br />Client Services<br />
www.bennetttrimtabs.com
