This is the info from the other thread, they were all measured the same.
Cam specs, from S10 Planet:
Factory 4.3L Cam Specs
* '96-'00, VIN W, w/ balance shaft
- Lift (I/E) - .415/.429
- Dur @ .050 (I/E) - .191/.195
* '93-'96, VIN Z, w/ balance shaft
- Lift (I/E) - .376/.402
- Dur @ .050 (I/E) - .183/.193
* '92-'95, Vin W, w/ balance shaft
- Lift (I/E) - .432/.440
- Dur @ .050 (I/E) - .208/.208
* '91-'93, ZR9/Z79, Syclone/Typhoon
- Lift (I/E) - .351/.386
- Dur @ .050 (I/E) - .179/.195 (Ductile)
* '90-'91, VIN Z, Astro/Safari
- Lift (I/E) - .403/.450
- Dur @ .050 (I/E) - .202/.213 (Steel)
* '87-'94, Vin Z, w/o balance shaft
That thread also stated that the 92-95 Vin W motors had 10 more hp than the Vin Z of the same year. Just curious if anyone else around here has tried running this cam and noticed any difference. The numbers definitely show a more aggressive profile so it would make sense... That being said, I totally agree with the above statement, just because the numbers look better doesn't mean it will perform better, I'm no engineer (actually I am) but not for engines lol... Just seems like if I'm swapping heads, it might be worth throwing this cam in.
