Camshaft upgrade 350 mag mpi
Trytten
I was wondering if anyone on here has upgraded their camshaft in their 350 mag mpi I've got a 2006 larson 226 and wanting a little more power and looking in to whipples upgraded ECM and a set of high flow exhaust manifolds looking for a mild cam upgrade nothing to wild
Plenty of cams a little better than the 350 Mag. However if youre looking for more umph, build a 383 stroker
Ayuh,.... 'n probably not even worthy of a bigger prop,....
A 383 built with Vortec heads, 'n matchin' pistons, quenched to 'bout .043", will no doubt need a bigger prop,.....
alldodge
The wipple is the easy way to build power just need to be sure your engine is in good condition, don't do it to a worn engine. Other wise the 383 as mentioned or bore the 350 and increase the compression a bit. The 383 will give you the most without a whipple
Volphin
Or you could go nuts and do the Whipple WITH a 383. woooooooooooo!
dont forget the cheater NOS fogger system as well.
Trytten
Yeah 383 would be great but little out of the budget right now I've read that wipple can reprogram the ecm for around 500 bucks to gain a little more power but they can also program for a cam upgrade that's what I was kinda thinking of doing for now I guess thanks for all the help guys
harleyman1975
Ensign
Just be aware that once you modify the engine you will have a harder time getting someone to work on it.
