Frank Acampora
- Jan 19, 2007
- 12,004
Re: Can a 1974 Chrysler75hp block be used to rebuild my 1989 Force 85hp block? UPDATE
Reeds and VEE blocks are the same on all 3 and 4 cylinder engines. There is no power to be gained by changing them. Even if you modify the engine and put in the later square-tipped reeds which are supposed to be more responsive, you will not gain power. Supposedly fiberglass aftermarket reeds or Boyeson reeds do give more power but I have never tried either. I HAVE tried streamlining the Vee block openings and manifold passages with again, no increase in power. I have tried drilling holes in the reed stop plates to help reduce reed sticking from the oil and again, there was no difference in power. So save youself some work. Unless you port the 75 and increase compression, it is going to produce somewhere around 75 HP no matter what you do.
You can try opening the reed stop plates a bit. There is a different and slightly larger specification for the higher horsepower engines but again, your gain will be minimal. Port timing is the major factor in horsepower development.
