Can a 2013-2014 3.5 be converted to a fuel pump tank setup?
handifly
Having trouble handling the weight every time I go out w the Intex Mariner 4. It has to go on and off every trip
Sea Rider
Re: Can a 2013-2014 3.5 be converted to a fuel pump tank setup?
Nope, this one uses a gravity carb. The ones that uses fuel pumps are mounted on side of carb, used on other models than 2.5-3.5 HP.
Happy Boating
handifly
I live on a lake w a rule against carrying gas cans
External fuel tanks are ok. Is there a way to pump fuel from the external tank into the integrated tank?
Packard8
How about using a regular OB external tank and using the primer bulb on the hose to refill the internal tank?
Shouldn't take too long to pump a gallon or two into the internal tank, even faster if you hold the external tank above the motor and let it syphon after getting it started with the primer bulb.
handifly
I have a news external OB tank and hose. Can anyone think of a way to attach a fuel cap to one end that will fit the built in tank? That way I can switch over without a mess
pvanv
There was once a vacuum-operated fuel pump option for the M3.5 2-stroke. I have installed them, and they work OK; they may still be available. Also, the newer 4-stroke MFS3.5B already has a fuel pump, because of the EPA-mandated pressure/vacuum fuel tank cap, so one could potentially connect a primer hose to that, but I can't advise making a non-compliant, and possibly dangerous setup; use your judgment.
