Nautique93
- Nov 10, 2008
- 40
1983 Mercury 70HP Power loss.
Can a faulty switchbox damage trigger or stator? I replaced stator as readings were well out of spec. Trigger read in spec. Full power returned for a couple of trips, then suddennly dropped to half power. New stator still tested good, but trigger now tested well out of spec. Are these components coming to the end of there life or could my switchbox be damaging them? I initially bought a used switchbox cheap when i first started having problems, and swapping switchboxes didnt affect the symptoms. Tryed swapping switchboxes again when the trigger gave up, with no change. Im worried either one of thses switchboxes could be damaging new parts, and should i spring for a new one of these as well, even though the switchboxes dont appear to be the problem?
Thanks, Peter
Thanks, Peter
