Can a slightly low battery cause no spark?
philtheskipper
I've been having problems with no spark on my Suzuki outboard. The other day I charged my batteries on a long trickle charge and it then fired right up. So, I went out on the lake and it ran great. My voltage meter showed it was charging good(both batteries). I got to my fishing spot and shut it off, then switched to just one battery. When I went to start it with both batteries it wouldn't start. Seemed like it was cranking as usual but after awhile it did start to slow a little. Do you think I just have a bad battery or something? The way it was cranking seemed like it had enough juice. Do these electronic ignition systems need 100% power to get a spark?
JB
Re: Can a slightly low battery cause no spark?
Depends on the year and model of your engine, Phil.<br /><br />Moving to Suzuki Troubles.
jim dozier
Before you get all wound up about the ignition go buy a spark tester and test the spark in each cylinder. If its OK your problem is probably fuel. There is a difference between no spark and no fire. Suzuki ignitions are pretty strong.
philtheskipper
Thanks for the advice jimd but I already checked the spark for each cylinder with my trusty home made tester. The spark plugs are getting wet when cranking so the fuel should be good. I just had the carbs rebuilt and cleaned at the end of June also. I'm off to have the batteries checked right now. Hopefully that's my problem.
jim dozier
No that is good. You have identified the problem :cool:
philtheskipper
I bought two new batteries today. Is two 500 cca marine batteries enough power for my engine? I bought them from Sears because that's what was in there to begin with and they lasted 5 years. My concern is the old batteries were 575 cca. Same model and size battery but they changed the ratings on them. I would of got the next size up but it won't fit in my battery compartment.
