I HAVE a 1998 Suzuki DF 60, EFI, 4 stroke which surges and won't go above 3200 rpm. If I stop the motor and ram throttle the motor jumps up and runs smoothly but still won't go over 3200 because of rev limiter. I have replaced high & low pressure fuel filters, fuel pump diaphram, new spark plugs, primer bulb, used a new aux fuel tank, new H2O impeller & housing (at a outboard marine shop) Shop cleaned the injectors, said compression was good. Fuel rail pressure was good. They changed oil & grease in lower unit. Only charged $300 because they couldn't figure out problem. Spent another $230 from an individual who works on motors. Said the coil was good, no air leaks, no bad sensors and thinks the ECM is bad. The part is $1100. I have an old pontoon boat and use it in a small fresh water lake. Anyone know of a place to send the ECM to be tested And repaired? Thanks
