Can anybody tell me what outdrive this is???
Bt Doctur
Re: Can anybody tell me what outdrive this is???
bad link to the pic
pcmpete
i will fix the link for you:
jolio55
Oh why thank you :p How'd you do that?
Howard Sterndrive
that is the OMC Sterndrive
it has no other names, but is often referred to as the electric shift stringer mount drive made from 1964-1977
it is the predecessor to the 400 and 800 series
pcmpete
Photobucket has a 'Share Option' then select get code, then paste it in your message.
P.S. I think the outdrive is an OMC Stringer, not 100% sure as I am a Volvo and Mercruiser man myself
Don S
It's an OMC stringer drive. Sorry.
PS: In photobucket, use the IMG code, not the HTML code if you want your pictures to show.
jolio55
So are these bad drives?? I am looking at buying this boat and I'm trying to research it out as much as possible...
Don S
The problem with them is when they fail. OMC went out of buisness in 98, and the last stringer drive was made in 85.
There are no techs with tools and training to fix those drives. Some online help, and lots of expensive aftermarket parts. Just very few with experience to do the work.
jolio55
Oh I see, well that's not good... Should it be a big enough reason not to buy the boat? It is a good deal the guy isn't asking a lot for it...
Don S
It would be a deal breaker for me. You can not replace it with any other outdrive setup due to the size of the hole in the transom and the thickness of the transom.
I wouldn't recommend an OMC to any first time boat owner that isn't a skilled marine tech that knows the drives and how to repair them.
Engine wise, they are GM engines. The drives are the problem.
The shift cable alone on a stringer can run over $400 let alone the labor to install it.
jolio55
:redface: Gotcha... So what kind of outdrive would you recommend for a newbie like me :D Mercruiser?
g33km3
Okay, i have used my 1985 OMC Stringer 400 quite heavily still has not broken so i would reccomed them....Hell i found i site that will take your outdrive and fix what ever is broken.
Howard Sterndrive
Mercruiser drive behind a Chevrolet engine
the only combo to look for when shopping as far as I'm concerned
here's why:
NEW replacement Mercruiser outdrive with 3 yr warranty from SEI: $1200
NEW 400 or 800 series drive from BRP with no warranty once used: $7230 (and only a few models are available upper and lower) lower unit is $4550
g33km3
here's why:
True, I do know Merc was started by OMC and so was Evinrude. I always felt OMC was superior....maybe the newer Mercs are better.
achris
More fish than mountain goat
Not even remotely true.... (and OMC have never been superior. Count the awards and 'firsts' Merc has.)
Outboard Motor Company was formed in 1929 when ELTO was merged with Lockwood-Ash Motor Company.
Mercury Marine began when engineer Carl Kiekhaefer purchased a small outboard motor company in Cedarburg, Wisconsin in 1939.
The 2 have always been fierce competitors, until the Japanese came in and messed the whole industry, and the world economy for that matter, up.
Chris.........
Bravo
Chris.........
That sounds a bit better, and interesting info to boot.
