Can anyone help with mariner 3 cylinder 75hp wiring
Bennettrj
Hi there I am iin need of wiring diagrams for a 75hp 3 cylinder mariner outboard serial number 9530342.
I was sent a link to a compressed manual which was very helpful but the only wiring diagram showed an engine with no low oil module wiring on it I have a low oil unit with.
Dark blue wire
2 light blue wires
A pink
A purple ????????? And I have no idea where they go thanks
carholme
Re: Can anyone help with mariner 3 cylinder 75hp wiring
See my message to you in Notifications at the top of the page.
Gerry
Texasmark
If this helps: On the Merc 90 cousin, the oil warning module has 5 wires:
Tan which is the OT/low oil level output wire to the alarm from the module. The OT signal (ground from the sensor) pigtails at this pin and goes back out not using any of the functionality of the module. The warning horn blasts a solid tone.
Lt. Blue has 2 inputs to the module, both of which come from the float sensor in the oil tank. If these two wires short together as happens with a low oil condition this causes the module to modulate the signal and sends a modulated signal to the warning horn which causes it to beep, beep, beep indicating the difference between the two faults for troubleshooting purposes.
Purple wire is the 12v input and is switched on at the control box. Red wires in the harness are directly wired to 12v but none are connected to this module in the Merc.
Black is to chassis gnd. aka battery - terminal.
No pink wires used in the Merc harness.
Mark
Bennettrj
Ok thanks I will take a look tomorrow. I also have a slim black box about 120mm long 20cm wide black plastic with 4 wires coming from it green green white and dark blue ??? It is totally unconnected I am guessing its for the power trim system wing ????
Bennettrj
It has a green white wire and white and green wire and a blue on one end and a black on the other ??????
carholme
As you haven't answered my PM to you, I presume that you have the service manual wiring diagrams. Have you checked them as that should answer both of your questions.
Gerry
Bennettrj
Gerry
Yes thanks I downloaded file so sent me and am truly grateful it has been a great help but the wiring on this little Black box does not match any shown in the manual 4 wires blu black green / white and white green. 3 one end one wire the other I'm sure it's some trim part but not sure where too wire it too ??
carholme
I am not talking about the condensed version of the Clymer manual, this is the actual Mercury service manual.
Gerry
Bennettrj
Yeah thanks Gerry I downloaded full manual. The other day but still can't find the diagram for this box
Texasmark
Blue and green are as you said trim wires. White stripe on a small gauge wire would indicate a control wire where the larger solid wires would do the work.
Mark
