Can anyone identify this prop?
CraigBarnard
Is there another way to determine which prop I have other than reading the numbers?
Its an old prop and the numbers are pretty much worn away.
The prop is on a 1965 Starcraft Cheiftain with a Mercruiser 120hp 4cyl. outdrive.
I have attached a pic on the chance someone can decifer it.
Thanks!
steelespike
Re: Can anyone identify this prop?
Usually the last 2 digits are the pitch 14 isn't likely a 19 maybe.Usually a prop shop; Where they fix props, can measure it for you.
If you had the gear ratio usually stamped on the leg; and can get us the present accurate max rpm and speed by gps
we may be able to ball park the pitch.Prop shop is the best bet.
