Can anyone identify this wiring?
rcb130
I have a 1999 OMC 70 Hp engine with model #J70PLEEE,engine family #X1PXM0056210. This motor is set up for the OMC systems check wiring.
However, at the rear of the motor below the spark plugs is the typical large round red amphenol type connector used on earlier models of evinrudes and johnson engines. This connector connects part of the wiring to a remote control setup. It shows up on no wiring diagram I have found in the service book. Can anyone identify it and its purpose? Is this the standard way OMC uses to extend wiring for remote setups?
Thanks in advance for the help.
rcb130
tashasdaddy
Re: Can anyone identify this wiring?
obviously you are not the original owner. sounds like the original owner, had an old control, and rigged the plug to make is connections. not totally unusual. i fixing to wire a harness directly into a motor, as it original engine harness is shot.
rcb130
Tashasdaddy,
Thanks for the help. I am not the original owner and your explanation makes total sense. Thanks once again.
Rcb130
