I have a 7.4 454 with a Holley carb (1990 Wellcraft) and low hours. At about 3,800 rpm, it starts to hesitate and will not accelerate beyond 3,900. I’m going through the issues, one at a time. Changed plugs, plug wires, cap/rotor, cleaned weights, check the Holley for linkage binding and more. This weekend, I’m changing the electric fuel pump and disconnecting the 4,800 RPM Rev LImiter (I can’t tell if it’s electrical and gas issue). Then, the anti siphon and tank.
Question: It will warm up to 150 then the gauge drops back to about 125 to 130. Never hotter. I’m going to purchase in IR probe and make certain that the gauge works. But, if the gauge is correct, will running cold (bad T stat) effect WOT like this?
I can’t run WOT and visually check the engine as the hatch will rip off. I’m thinking of buying one of those camera snakes to install inside the hatch to check the everything. Any better ideas on that part?
Should I just change the T stat anyway? It’s 28 years old now.
Thanks for your help, driving me nuts. Summer is going to be gone in 4 more weeks....
