Phishnvdub
- Jun 16, 2012
- 46
Hi guys, I have read about adding a tell tale to the plug infront of the thermostat housing. In the pics you can see I have this plug to the right of the T-stat housing on top of some kind of channel that runs from top to bottom of the cylinder head cover. there is actually another plug on the bottom. I am curious if could remove that top plug and add a fitting for a tell tale there? Is that channel a water line for cooling? One other question quick, in the other pic. There a hose behind the shift linkage I just noticed today and was curious what it was for? It runs to a fitting in the front of the motor under the carb I think.
