Can I add temperature switch here?
kaliona
1978 165hp I6. Purchased an engine alarm kit with oil pressure and engine temp switches. The new temp switch is 3/8" npt and just want to make sure I install it in the right location. There are two plugs on my t'stat housing, but they look like 1/8" or 1/4" npt. One plug is right next to the original temp sender below the t'stat, and the other plug is above right next to the t'stat. Which should I use for the new switch? Do I need to get a reducer? Or do I get a tee and mount both the sender and switch on the original port? Also can I just get whatever fittings I need from Napa or any old hardware store? Brass. . . stainless. . .does it matter? Pic of what I have is attached. DSCN3369.JPG Thanks
yes, and you get a pilot drill and a 3/8" pipe tap, and you open one of the holes to 3/8" NPT.
you will get false readings if you attempt an adapter or a pile of fittings.
kaliona
Thanks, I'll try enlarging and tapping the hole next to the existing temp sender. I hope there's enough meat there to do it.
Fun Times
kaliona
Fun Times, would be ideal if one of those two plugs were 3/8". Unfortunately they're both 1/8". So I'm going to have to drill and tap one of them.
JustJason
Weatherhead makes brass adaptors with holes in the middle of them to allow for fluid transfer. This is a basic temp switch, I can't see why it wouldn't work.....
Alumarine
I have the same 47587 manifold as you on my 1980 3 liter.
On mine the plug to the left of the temp sender is 3/8 npt.
On yours it certainly looks smaller than that though.
On my 1974 3 liter the plug is smaller like yours.
Fun Times
There seemed to be a change in plug size between serial number ranges back then.
3622-32803--PLUG, PIPE-WATER DISTRIBUTION BLOCK (click here) SERIAL 00000000-03464447$4.60$4.491
3622-328022--PLUG, PIPE-WATER DISTRIBUTION BLOCK (click here) 22-32802SERIAL 00000000-03464447$4.90$4.781
35861493A07BLOCK ASSEMBLY, WATER DISTRIBUTION-CYLINDER BLOCK63908A2SERIAL 03464448-09999999$123.67$111.491
3622-328022--PLUG, PIPE-WATER DISTRIBUTION BLOCK (click here) 22-32802SERIAL 03464448-09999999
