engine starts right up and generally runs perfect....only issue is idle is only 400-500...barely above stall out...does not surge or anything...just a low idle...i know it should be closer to 700.
i read another post here re: adjusting idle...loosen pickup screw, align center throttle control cam roller, turn throttle stop screw to right to increase idle, tighten up pickup screw...
but somewhere else i read idle on this can't be adjusted just with a screw..that its all controlled by the computer...
thanks
thanks
