Ace Scallywag
- May 29, 2012
- 6
has anybody done this? I want to do a 100% closed cooling system on my boat.
Just remember, you need all those hoses, and the thermostat housing, and block off gaskets under the risers.actually might already have one... Smells like antifreeze in the cap..
i'm new... I know hot rods, not boats.. So no its not a trick question... It's called learning.
absolutely 100% can. I done it on both my 1979 cobia sportster and my 1978 glastron 178ssv. all you have to do is cap off your exhaust to the outdrive, get rid of the engine cover, use a regular car exhaust manifold or headers and run your exhaust over the transom. lot easier if its a v8 or v6 but 4 & 6 cyl is doable I done my glasstron through the transom. rest is just building brackets to support the radiator and building a screen over the front of the radiator. i used expanded metal and also built a expanded metal deck over the engine compartment it gets plenty of airflow. all you need is a 2 row 19x 21 radiator for a racecar and whatever electric or mechanical fan you choose.has anybody done this? I want to do a 100% closed cooling system on my boat.
Ayuh,.... Welcome Aboard,.... Please read, 'n follow our posting rules, 'n guidelines,.....absolutely 100% can. I done it on both my 1979 cobia sportster and my 1978 glastron 178ssv. all you have to do is cap off your exhaust to the outdrive, get rid of the engine cover, use a regular car exhaust manifold or headers and run your exhaust over the transom. lot easier if its a v8 or v6 but 4 & 6 cyl is doable I done my glasstron through the transom. rest is just building brackets to support the radiator and building a screen over the front of the radiator. i used expanded metal and also built a expanded metal deck over the engine compartment it gets plenty of airflow. all you need is a 2 row 19x 21 radiator for a racecar and whatever electric or mechanical fan you choose.
if you want a through hull exhaust get 2 3 inch header collectors black or chrome your choice with a 2 inch outlet. drill a 3 inch hole at the top of the transom. bolt your collectors together with gaskets one inside the hull and one outside the hull. measure the distance from where each collector starts to taper. cut a piece of 3" exhaust tubing to that length and weld to the inside of the first collector. make sure it bottoms out in the collector. next take a piece of 2" OD exhaust tubing and cut it to where it sticks out about 2" on each side of the collectors. before you bolt the other half on pack as much loose strand fiberglass as you can in between the two walls of the collectors. essentially you're building a double wall to keep heat out of the transom. bolt together the collectors and weld the 2" sections and your done. if you want to dress up the outside you can get a stainless steel 3" collector and slip it over the collector on the outside of the transom. inside the boat just run 2" flexible exhaust tubing and your muffler of choice.
