Can I change my 88 spl into a 120????
Colelj
Some one told me that from a 88 hp to a 140 hp all the Johnsons were the same except for the carbs and exhaust. So my question is, if I find a blown 120 can I take the carbs and exhaust off it and put on my 88 and have a 120?
Faztbullet
Re: Can I change my 88 spl into a 120????
No as a 120 is a looper and yours is a crossflow. The block exhaust porting is also different on various hp's.
1946Zephyr
You can probably mount a 120 powerhead on yours.
wilde1j
Why not just buy a bigger motor and sell the 88?
emdsapmgr
Fastbullet is correct. The later 120/140's are big bore loopers. Completely different engine. When compared to the older 140 crossflow engines, though similar-even those blocks are different. The 140 has different porting and has the bubble back exhaust. Not easy to convert your 88 to that configuration. You can add the older high compression heads and the larger 1 5/16" carbs. Those are bolt-on hp additions. (you will probably have to rejet the carbs somewhat.) Also, add the rubber intake filler blocks by the reeds. (they are good for 3-5 hp, but are NLA-so you will have to scrounge around for them.) Composite reeds are also a nice addition. You may get it up to 125 crank hp with the bolt-on adds.
Colelj
Ok thanks for all the info. @wild1j, thats what Im gonna have to do. I am rebuilding my 88 laser 1720 and I can go up to a 120 so I want to go as big as I can. lol
