Can I clean inside Tilt Ram with Carb Cleaner??
aussieflash
G'day all,When I eventually get the cap off tilt ram, I'm going to rebuild,seals,o ring etc.Manual says to clean with Parts Cleaner?? could I use Carb cleaner or should I just use a solvent(mineral Turps)then blow it out.
Chris1956
Re: Can I clean inside Tilt Ram with Carb Cleaner??
I do not think there is a need to use Carb Cleaner. I would stick with turpentine or maybe acetone.
aussieflash
Thanks Chris.I'll stick with the Turps.
